On Sep 16, 2009, at 5:25 PM, grass-dev-request@lists.osgeo.org wrote:
Date: Wed, 16 Sep 2009 19:08:38 -0000
Subject: [GRASS-dev] [GRASS GIS] #750: wxGUI: scalebar loses focus
To: undisclosed-recipients:;
Message-ID: <040.a968f51a41a425b4779ef44b0d9f7177@osgeo.org>
Content-Type: text/plain; charset="utf-8"#750: wxGUI: scalebar loses focus
Reporter: hamish | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: minor | Milestone: 6.4.0
Component: wxGUI | Version: svn-develbranch6
Keywords: | Platform: Linux
Cpu: x86-64 |
Hi,in the wx Map Display window if you add a scalebar, drag it to the bottom
left, then add a raster legend, after that it is not possible to drag the
scalebar any more, even if you reselect add scalebar from the add overlay
menu. The legend gets dragged around instead.??
Hamish
What is happening is not quite what it appears. The real problem is that both the scalebar and legend are "maps" because that is how GRASS draws them. The invisible "maps" are the same size as the screen. When you put both a legend and a scalebar on a real (i.e., visible) map and they overlay each other it is sometimes hard to grab the underlying element. If you move the legend out of the way, you can grab and move the scalebar.
There is probably a way to fix this but I didn't figure it out when I first did this, and it hasn't been high enough on the priority list to fix afterwards. What is needed is to somehow clip the graphic of the legend and scalebar so that it closely conforms to the element. However, this would also need to change size if the element changes size.
Michael
