Hi
Il giorno 20/set/09, alle ore 02:11, Martin Landa <landa.martin gmail.com> ha scritto:
Oggetto: Re: [GRASS-dev] wxgui problem (grass -r 39224 linux x86_64 “sidux” )
2009/9/19 Massimo Di Stefano <massimodisasha@gmail.com>:
my swig version is : 1.3.39
yes, that’s same here - I use Debian Sid and wxpython from packages
apt.widgets.org. In this case wxPython is build probably with 1.3.36.
i’m on a debian sid derived distro, using the official debian-sid repository
what’s wour source.list line to add the wx widjet repository ?
i have found this page :
http://wiki.wxpython.org/InstallingOnUbuntuOrDebian
but there is no “sid” only lenny or “etch”, shoul’d be good this one, using etch ? :
# wxWidgets/wxPython repository at apt.wxwidgets.org
deb [http://apt.wxwidgets.org/](http://apt.wxwidgets.org/) etch-wx main
deb-src [http://apt.wxwidgets.org/](http://apt.wxwidgets.org/) etch-wx main
