On Oct 16, 2009, at 7:33 AM, grass-dev-request@lists.osgeo.org wrote:
Date: Fri, 16 Oct 2009 12:08:48 +0200
Subject: Re: [GRASS-dev] wxGUI: "Save display to graphic file" and
d.out.file options
To: Markus Neteler <neteler@osgeo.org>
Cc: GRASS developers list <grass-dev@lists.osgeo.org>
Message-ID:
<f8fe65c40910160308wf56281ck9131d2d0b3b30148@mail.gmail.com>
Content-Type: text/plain; charset=ISO-8859-1Hi,
2009/10/16 Markus Neteler <neteler@osgeo.org>:
resolution and such. Since d.out.file already generates wxpython code
could it be recycled in the GUI? (d.out.file fails and wants an X monitor).is there any reason why d.out.file requires X monitors? It would be
cool to have d.out.file also in GRASS7.Martin
d.out.file started it's life as d.out.png, a script I wrote to create a graphics file from a GRASS screen display, way back in the early days of GRASS 5. It uses the command history function that requires an xmon to recreate the command sequence that produces the graphic display with the output set to PNG instead of an xmon. This does not work in the TclTk GUI or in wxPython because of the xmon requirement.
To make this work, it would need to be rewritten inside the GUI where it could capture the sequence of display commands from the rendering module and redirect them to a named graphic file instead of the internal PNM file that is displayed in the canvas. In that code, you could alter the output resolution by changing GRASS environmental variables to something other than screen resolution.
This is not an extremely difficult task, and I'd support putting it into the GRASS 7 queue as a desirable enhancement.
Michael
