Hi Markus,
How much memory was available on the machine? If the machine had more than 512MB RAM, it is not fair to run terracost running with mem=400MB, and compare it with an algorithm that can use more memory.
However, I am surprised that withnumtiles=1, it was slower than r.cost. That's something I'd like to look into. Would you mind sharing the raster with me, and sending me the exact commands that you ran?
A grid with 29M points is pretty small, for today's machines. I suggest running on something 10 times larger. And use a lot of sources, that makes the data access pattern less local.
-Laura
Message: 1
Date: Fri, 06 Nov 2009 09:50:02 +0100
From: Markus Metz <markus.metz.giswork@googlemail.com>
Subject: [GRASS-dev] comparing r.cost and r.terracost
To: GRASS developers list <grass-dev@lists.osgeo.org>
Message-ID: <4AF3E33A.1090208@googlemail.com>
Content-Type: text/plain; charset=ISO-8859-1; format=flowedSame test region as before
North Carolina sample dataset
g.region rast=elev_state_500m@PERMANENT res=100
# gives about 28 million cells
v.to.rast nc_state@PERMANENT use=val val=500.0 out=cost --o
v.to.rast urbanarea@PERMANENT use=val val=1 out=urbanarea --o
r.cost in=cost start_rast=urbanarea out=dist_urban percent_memory=20 --ograss7 r.cost
real 0m55.349s
user 0m53.360s
sys 0m1.797sgrass65 r.cost
real 26m35.166s
user 2m55.612s
sys 23m37.921sr.terracost: check optimal tile size for 400MB memory (default setting;
r.cost in grass7 used 135MB with 20% of maps in memory)
r.terracost in=cost start_rast=urbanarea out=dist_urban_terracost -i
TILESIZE: nc_spm_08 N=28064550 elements, M=419430400 bytes, optimal
numtiles=1870r.terracost numtiles=1870, intermediate data are stored on disk as
r.cost does
real 25m13.593s
user 22m46.978s
sys 1m8.059sr.terracost numtiles=1, all in memory (just fits into 400MB)
real 0m17.969s
user 0m17.276s
sys 0m0.500sAccording to Laura Toma, when comparing r.cost with r.terracost,
numtiles must be >1 for r.terracost in order to compare disk I/O
algorithms [1]With these test settings that intentionally reduced memory consumption
in order to test disk I/O performance, r.terracost is not really faster
than r.cost in grass65 and much slower than r.cost in grass7.Markus M
[1] http://lists.osgeo.org/pipermail/grass-dev/2009-July/045157.html
grass-dev mailing list
http://lists.osgeo.org/mailman/listinfo/grass-devEnd of grass-dev Digest, Vol 43, Issue 8
