On Feb 18, 2010, at 3:45 PM, grass-dev-request@lists.osgeo.org wrote:
Date: Thu, 18 Feb 2010 23:30:38 +0100
Subject: [GRASS-dev] how to work on wxGUI?
To: grass-dev@lists.osgeo.org
Message-ID: <hlkf2c$isp$1@ger.gmane.org>
Content-Type: text/plain; charset=ISO-8859-15Hello,
I would like to perform some work on wxPython GUI Dialogs.What is the recommended way to edit the python files?
Do I need to complie GRASS in order to see the changes?
No. Python recompiles automatically at run time for any module whose source has been changed since last run time.
Is there a possibility to run the GUI locally from the source directory?
Just change it in your binary directory so you can test it repeatedly. Then when it is correct, move the changes to your source version.
Michael
Best regards,
Timmie
