[GRASS-dev] Re: grass-dev Digest, Vol 68, Issue 41
On Oct 27, 2011, at 10:00 AM, <grass-dev-request@lists.osgeo.org> wrote:
Date: Wed, 26 Oct 2011 20:30:23 +0100
Subject: Re: [GRASS-dev] r.mapcalc in Python script (parse error)
To: Margherita Di Leo <dileomargherita@gmail.com>
Cc: grass-dev@lists.osgeo.org
Message-ID: <20136.24527.829595.733755@cerise.gclements.plus.com>
Content-Type: text/plain; charset=us-ascii
Margherita Di Leo wrote:
I need a little help with r.mapcalc syntax in Python script. I want to
convert the following formula:
grass.run_command('r.mapcalculator', amap = r_stream+'_nothin' , formula =
'%s*%s' % (r_stream+'_nothin', r_mask) , outfile = r_stream+'_nothin',
overwrite = True)
I want to use r.mapcalc instead of r.mapcalculator. So I write:
grass.mapcalc("$r_stream_nothin = $r_stream_nothin * $r_mask",
                     r_mask = r_mask,
                     r_stream_nothin = r_stream+'_nothin')
but I get parse error. What's the correct way to do this? The aim is to add
the suffix '_nothin' to the existing variable name r_stream.
There's nothing obviously wrong with the above code, although you
should probably quote the map names, i.e.:
       grass.mapcalc("'$r_stream_nothin' = '$r_stream_nothin' * '$r_mask'",
Map names which contain symbols need to be quoted, otherwise e.g. a
map named "map-name" will be parsed as a subtraction.
Check the values of r_stream and r_mask with e.g.:
       print repr(r_stream), repr(r_mask)
Running 'g.gisenv set=DEBUG=1' prior to the script will enable some
debugging information, including the exact r.mapcalc command.
Also, using the same map as both input and output is unwise. It
appears to work, at least for simple cases, but shouldn't be relied
upon.
You've got the string substitution wrong may need to use more string substitution. I'm assuming that r_stream is a variable
The first statement is...
overwrite = True)
You should rewrite it as...
grass.run_command('r.mapcalculator', amap = '%s_nothin' % r_stream , formula =
'%s_nothin' * %s' % (r_stream, r_mask) , outfile = '%s_nothin' % r_stream,
overwrite = True)
You could do something similar with r.mapcalc instead of r.mapcalculator (note that r.mapcalculator is no longer present in GRASS 7)
In the second statement, I think the format should be...
grass.mapcalc("'%s_nothin' = '%s_nothin' * '%s'" % (r_stream, r,stream, r_mask))
Using the "$" does not work on my system at least.
Michael
grass.mapcalc() substitutes the arguments into the expression using
string.Template.substitute():
http://docs.python.org/library/string.html#template-strings
