Ravinder Singh Bhalla wrote:
Dear Michael,
I'd be happy to contribute some time for the documentation. It would really help if someone coordinated the effort - pointing to specific modules needing work.
Ravi
Thanks very much for the offer of help. Coordination would be very helpful of course. However, anyone can look at modules they know well and work to update them.
Here are somethings to know about doing this (Markus might want to add more suggestions).
1. The doc/help file needs to be retrieved from the source code. If you don't compile GRASS yourself and don't want to deal with cvs, you can download this from the web access to the GRASS source tree. This will move to a new location fairly soon. But for now, it is at <http://freegis.org/cgi-bin/viewcvs.cgi/grass6/>
2. The doc page is located inside the directory/folder for the module source code. For example, the doc file for r.info is found inside the grass6/raster/r.info folder
3. The doc page for a normal module or script is named description.html. Hence, to see and download the doc page for r.info, go to <http://freegis.org/cgi-bin/viewcvs.cgi/grass6/raster/r.info/>\.
4. The doc page is just plain ASCII text with html tags. You can look at it in any text editor or an html editor. BUT CAUTION. Many slick html editors will try to add in extra tags (CSS or other). MS Word is especially notorioius for this. If you want to use an html editor, I can recommend KompoZer. It is an open source WYSIWYG html editor (successor to NVU) and located at <http://kompozer.sourceforge.net/>\. Make sure you turn OFF cascading style sheets in the preferences.
5. In the description.html file, you will notice that the name and basic name of the module/script and basic list of its options are missing. It is SUPPOSED to be that way. DON'T add this information back in. It is automatically generated from the module itself.
6. The doc file starts with the description of how the module/script works. This is where it will be really nice to have some input. Richer description, fix typos and grammatical errors, add graphics, add examples, etc. Any graphics should be in PNG format and pre-scaled to the proper size. Make them legible, but not too big. GIMP does a good job of scaling (use the cubic convolution resampling method, as it looks better). ImageMagic also works well if you like the command line. The image reference should be entered with the assumption that the image is in the same directory as the doc file.
7. How to get the updated help file into GRASS. This is where a coordinator would be very helpful. Until someone volunteers for this, maybe Markus will suggest a way to do this that does not make too much work for him. There is probably a way/place to submit such updates so that member of the development team with CVS access can get it into GRASS (e.g., the current bug tracker, though like the CVS, this too is slated to change soon).
Thanks again for helping.
Michael
Professor of Anthropology
Director of Graduate Studies
Arizona State University
Phone: 480-965-6262
Fax: 480-965-7671
WWW: http://www.public.asu.edu/~cmbarton
