#1: g.setproj bug: latitude_of_center and longitude_of_center ignored
Reporter: neteler | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.3.0
Component: default | Version: svn-trunk
Resolution: | Keywords: proj
Comment (by martinl):
Replying to [comment:3 pkelly]:
> Re: the commented-out 7-parameter transform
> I originally put this in and the source is now at
http://www.asprs.org/resources/grids/08-2001-swiss.pdf
> As far as I can remember the two reasons I left it commented were:
> 1) The parameters given are for CH1903+ which is apparently different
from CH1903 - I have no idea how much or if the differences are big enough
to be relevant.
> 2) I didn't have any test points to verify the parameters - in
particular we always need to check the sign of the 3 rotation parameters
(the 4th, 5th and 6th numbers out of the 7) as the American/European
conventions are different.
> If somebody can verify these two points then we can uncomment the
parameters.
I cannot varify it (maybe someone in grass-dev/user ML), but I would vote
for uncomment the parameters and close the ticket (or to postpone it for
6.4).
Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/1#comment:5>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
