On Dec 17, 2008, at 12:22 AM, <grass-dev-request@lists.osgeo.org> wrote:
Date: Wed, 17 Dec 2008 07:22:45 -0000
Subject: [GRASS-dev] Re: [GRASS GIS] #295: region corrupted
To: undisclosed-recipients:;
Message-ID: <051.2301d585497eab3a94c92ac263194240@osgeo.org>
Content-Type: text/plain; charset="utf-8"#295: region corrupted
Reporter: msieczka | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: critical | Milestone: 6.4.0
Component: wxGUI | Version: svn-develbranch6
Resolution: | Keywords:
Platform: All | Cpu: All
Comment (by hamish):ok, so it is a matter of expectations.
how to improve the wording?
* I think all the "Zoom display to ..." menu items can stay as-is, as it
is not as critical if the display region is slightly askew. -- it's just a
visual thing. So vague language is ok here.* My suggestion to solve this ticket is to reword "'''Set computational
region extents to match display'''". It is critical to have the
computational region set cleanly for computations, and g.region -a is
needed to avoid sloppy regions set from the display. So crisp language is
needed to explain this.Replace "to match" with "from"? that makes it more technically correct,
but still doesn't address the user expectation issue very well.
Replace "Set" with "Align"? That puts forward the idea that the two grids
are still somewhat independent.how about: "Align computational region to current display"?
This sounds fine. I need to look at the code again, but I'm pretty sure that most of the variance reported here is in the "Zoom display to computational region..." step. The display is designed to fit in the window regardless of whether the computational region has the same proportions as the window or not. The computational region can be seen with a colored rectangle that can be turned on or off.
When you 'Zoom computational region to display...', the region extents are actually set to match the display. I suppose there could be a pixel/grid cell difference, but the algorithm simply takes the display extents in real world coordinates and puts those into g.region.
If "align" seems a more accurate way to phrase this, then I'm in favor of it.
Michael
