[GRASS-dev] Re: [GRASS GIS] #660: v.delaunay producing incorrect results
v.voronoi has always worked with OS X. I use it in my work. Is v.delaunay that is broken since it was replaced with the Summer of Code project.
Royce
> Comment (by kyngchaos):
>  Same output on archsites for me.
>  v.voronoi appears to work, on archsites.  I don't have a large point file
>  to test it - Michael?
> Comment (by cmbarton):
>  I tried v.voronoi on 1000 elevation points in the SC demo data set. It
>  took only a couple seconds and worked fine.
>  Michael
