#962: wxGUI crash when moving an undocked map display toolbox
Reporter: msieczka | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 6.4.0
Component: wxGUI | Version: svn-releasebranch64
Keywords: toolbar | Platform: All
Cpu: x86-64 |
Changes (by hamish):
* keywords: => toolbar
* platform: MSWindows Vista => All
Comment:
just another data point:
I can reproduce this in 6.4 and 6.5, but I have to try for a minute or two
first (it's on a rather fast machine, which may help, although I am
running X tunneled over ssh from it). I got no error message when the
wxGUI was launched automatically at startup.
I notice that draging the toolbar is not the most responsive thing once a
map is loaded. I had to try harder in 6.5, but that might just be chance.
Running same Debian/stable (lenny) amd64 with python-wxgtk2.8 version
2.8.7.1-1.1+lenny1 and python 2.5.2-3.
Also I notice that if I remove or uncheck everything on the list the last
map standing does not clear from the display window. If I press the erase
button, the image comes back after I tear-away or reconnect the display
toolbar.
I suspect that this is an upstream bug, and there is little we can do
about it.. but no idea.
wow, I just restarted grass in text mode and then g.gui from the command
prompt, and it died after adding a raster map and then a vector map with:
(hamish:10965): Pango-CRITICAL **: pango_break: assertion `attrs != NULL'
failed
(hamish:10965): Pango-WARNING **: shaping failure, expect ugly output.
shape-engine='BasicEngineFc', font='Bitstream Vera Sans 9.9990234375',
text=''
maybe I should try restarting X now..
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/962#comment:4>
