[GRASS-dev] Re: [GRASS-PSC] i.ortho.photo
On Thu, 2006-12-14 at 21:48 -0700, Michael Barton wrote:
Brad,
I haven't used the module, so I can't say. The reason for making it
*possible* to run non-interactively (even if it *can* be run interactively
if desired) is that it can then be wrapped into a non-x11 GUI. As long as
interactive terminal input is required, this is not possible.
Excellent point. I hadn't considered alternative GUIs.
There is no problem running the module twice in different modes to have it
compute transform coordinates, so long as those coordinates can be output to
stdout or a file that could be subsequently used by the module running in
different mode. On the other hand, if this involves interactively clicking
on photo reference points and a georeferenced map to create a file of point
pairs (photo/image and georeferenced equivalents), there should be the
option of replacing this task by GUI code. For example, the TclTk
georectifier integrates i.group, i.target, and i.rectify. However, the
interactive i.points is simply replaced by TclTk code that generates a POINT
file used by i.rectify.
Right now, coordinates are stored in the REF file. I assume the same is
true for i.points/i.rectify, but haven't reviewed that code, yet.
I'm not sure if this is helpful to you or not. However, to incorporate this
into a current or new GUI, there needs to be some way to run this module or
its decendent(s) 100% non-interactively.
Yes, this has been helpful.
Michael
On 12/14/06 9:22 PM, "Brad Douglas" <rez@touchofmadness.com> wrote:
> I've thought about adding options for input transforms coordinates, but
> I'm not certain how useful it would be. Do you think it's something
> that would be useful? How often would users know ahead of time what the
> coordinates were? Perhaps for re-projection?
> One of the goals is to remove as much interactivity as possible, so I'm
> quite interested in alternatives. I still intend on leaving that
> portion interactive, but have considering "bypass" options.
> On Thu, 2006-12-14 at 21:11 -0700, Michael Barton wrote:
>> My only comment is to encourage you in trying to find a way to make
>> i.orthophoto work in a non-interactive mode, at least as one option. As to
>> the C code changes, I cannot comment.
>> Michael
>> On 12/14/06 7:59 PM, "Brad Douglas" <rez@touchofmadness.com> wrote:
>>> dem_opt->required = NO;
>>> dem_opt->multiple = NO;
>>> dem_opt->description = _("Digital Elevation Model");
>> __________________________________________
>> Michael Barton, Professor of Anthropology
>> School of Human Evolution & Social Change
>> Center for Social Dynamics & Complexity
>> Arizona State University
>> phone: 480-965-6213
>> fax: 480-965-7671
>> www: http://www.public.asu.edu/~cmbarton
Brad Douglas <rez touchofmadness com> KB8UYR/6
Address: 37.493,-121.924 / WGS84 National Map Corps #TNMC-3785
