On Wed, Aug 6, 2008 at 2:57 AM, <svn_grass@osgeo.org> wrote:
Modified:
grass/trunk/raster/r.colors/main.c
Log:
Remove color=rules (redundant; use -i instead)
I have updated the description.html accordingly.
But:
-i Enter rules interactively
I find this description somewhat misleading for the example in
description.html (think newcomer here):
"The color table can then by assigned to map 'threecats' by the following
GRASS command:
cat rules.file | r.colors -i map=threecats
Suggestions for better wording in the flag description (main.c)?
Markus Neteler wrote:
> Modified:
> Log:
But:
GRASS command:
"Read rules from standard input (stdin)"
On Wed, Aug 6, 2008 at 5:47 PM, Glynn Clements <glynn@gclements.plus.com> wrote:
> Modified:
> Log:
But:
GRASS command:
Possibly you didn't submit? Or am I looking at the wrong file?
[neteler@markus r.colors]$ pwd
/home/neteler/grass70/raster/r.colors
[neteler@markus r.colors]$ nl main.c
1 /****************************************************************************
2 *
3 * MODULE: r.colors
4 *
5 * AUTHOR(S): Michael Shapiro - CERL
6 * David Johnson
7 *
8 * PURPOSE: Allows creation and/or modification of the color table
9 * for a raster map layer.
180 flag.i = G_define_flag();
181 flag.i->key = 'i';
182 flag.i->description = _("Enter rules interactively");
>> But:
I didn't change it, I just offered the suggestion.
But I've just removed -i from 7.x in favour of "rules=-".
