svn_grass@osgeo.org pisze:
Author: glynn
Date: 2008-08-23 22:20:30 -0400 (Sat, 23 Aug 2008)
New Revision: 33046
Modified:
grass/trunk/lib/cairodriver/Graph.c
grass/trunk/lib/pngdriver/Draw_line.c
grass/trunk/lib/pngdriver/Polygon.c
Log:
Fix bug with cairo driver failing to erase background
Fix bug with PNG driver skipping topmost line of polygon
Change PNG driver's line-drawing to use FP throughout
From the changes as above, is the "Fix bug with PNG driver skipping topmost line of polygon" appropriate for backporting?
Maciek
Maciej Sieczka
www.sieczka.org
Maciej Sieczka wrote:
> Author: glynn
> New Revision: 33046
> Modified:
> Log:
No.
The display architecture has been substantially rewritten to use
floating-point coordinates throughout. In most cases, it isn't
practical to backport changes.
I suspect that this particular bug was introduced in the conversion to
FP, so there's nothing to backport.
