% is not a comment, it's just suppress internal link. Now 'vector' is
linked to vector structure which is wrong. I am not sure it is
possible to globally suppress linking of given words. So 'vector'
would be not linked to 'vector' structure without need to use
'%vector'.
On Thu, Sep 4, 2008 at 12:12 PM, Martin Landa <landa.martin@gmail.com> wrote:
Markus,
'%vector'.
OK. The problem is that
"vector: Vector_Library (GRASS Vector and Direct Graph Library)"
is no longer expanded as link. Someone just asked me if the
vector lib is not documented and I discovered that the link is
no longer generated at all. I just tried a fix but it isn't expanded...
it should be
<li>%vector: \ref Vector_Library (GRASS Vector and Direct Graph Library)
it should be
