[GRASS-dev] Re: [GRASS-SVN] r33885 - grass/trunk/include
2008/10/15 <svn_grass@osgeo.org>:
+#define GISPROMPT_COLOR "old,color,color"
is it really necessary to recover this macro? It's only one used here.
If so maybe we should define other standard gisprompts in the similar
way (e.g. "old,vector,vector", "old_dbcolumn,dbcolumn,dbcolumn",
etc.).
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
etc.).
After it was removed, much of display/d.* failed to compile (30 uses
in 17 modules). Before it can be removed, anything which uses it needs
to be converted to use either an equivalent G_define_standard_option(),
or the literal string.
2008/10/15 Glynn Clements <glynn@gclements.plus.com>:
etc.).
sorry, I have overlooked that. Anyway, is it better to define
and other standardized gisprompts in gis.h
or just remove GISPROMPT_COLOR and fix the all modules by using
G_define_standard_option()?
Martin
>> etc.).
It should probably be "color,color,color".
In 7.0, it doesn't matter. Apart from the GUI, the value of the
->gisprompt field is only significant in terms of whether the first
component is "new". If any option has "new", then the --o[verwrite]
flag is included in the help text, interface description, etc.
In 6.x, the ->gisprompt field affects the terminal-based interaction
which occurs if GRASS_UI_TERM is set and you don't provide any
arguments. If the age is "old", then it will use G_ask_old(); if the
age is unrecognised, it will just prompt for a string.
Using G_define_standard_option() is preferable. Apart from anything
else, it will mean less work if we subsequently change the Option
structure.
