[GRASS-dev] Re: [GRASS-SVN] r34445 - in grass/trunk: include lib/gis
On Sun, Nov 23, 2008 at 2:41 AM, <svn_grass@osgeo.org> wrote:
Author: glynn
Date: 2008-11-22 20:41:03 -0500 (Sat, 22 Nov 2008)
New Revision: 34445
Modified:
  grass/trunk/include/gisdefs.h
  grass/trunk/lib/gis/alloc_cell.c
  grass/trunk/lib/gis/cats.c
  grass/trunk/lib/gis/cell_stats.c
  grass/trunk/lib/gis/clicker.c
  grass/trunk/lib/gis/closecell.c
  grass/trunk/lib/gis/datum.c
  grass/trunk/lib/gis/env.c
  grass/trunk/lib/gis/get_ellipse.c
  grass/trunk/lib/gis/get_row.c
  grass/trunk/lib/gis/get_row_colr.c
  grass/trunk/lib/gis/gisinit.c
  grass/trunk/lib/gis/list.c
  grass/trunk/lib/gis/mach_name.c
  grass/trunk/lib/gis/mask_info.c
  grass/trunk/lib/gis/myname.c
  grass/trunk/lib/gis/null_val.c
  grass/trunk/lib/gis/parser.c
  grass/trunk/lib/gis/percent.c
  grass/trunk/lib/gis/popen.c
  grass/trunk/lib/gis/proj3.c
  grass/trunk/lib/gis/put_row.c
  grass/trunk/lib/gis/reclass.c
  grass/trunk/lib/gis/spawn.c
  grass/trunk/lib/gis/view.c
Log:
Reduce use of static variables
Miscellaneous clean-up
... a 6.4. backport candidate? Say, those which are successfully
merged or could this destabilize 6.4.libgis?
Markus (who likes cleanup)
> Author: glynn
> New Revision: 34445
> Modified:
> Log:
You'll need to consider the chunks individually.
Most of them are safe, but some of them depend upon previous changes
which may or may not have been backported. E.g.:
+ Some of the changes to get_row_colr.c involve using G__alloca(),
which may not be in 6.4.
+ The percent.c change amounts to removing G_percent2(), which was
part of the vector library's "alternative" logging mechanism. Whether
that can be removed depends upon whether anything is still using it.
+ The put_row.c change removes G_zeros_r_nulls(). That isn't used in
7.0, but I don't know if it's used in 6.4. The sort of code which
might use that function is exactly the sort of code which was removed
in 7.0.
OTOH, most of the changes are harmless.
