[GRASS-dev] Re: [GRASS-SVN] r34771 - in grass/trunk/gui/wxpython: gui_modules xml
2008/12/7 <svn_grass@osgeo.org>:
Author: glynn
Date: 2008-12-07 02:16:10 -0500 (Sun, 07 Dec 2008)
New Revision: 34771
Added:
  grass/trunk/gui/wxpython/xml/menudata.xml
Modified:
  grass/trunk/gui/wxpython/gui_modules/menudata.py
Log:
Convert menu data to XML
Thanks for converting menu data into XML! I just wonder how to localize it...
Martin
PS: Sorry to all for today's mess in SVN (trunk/devbr6 -> menudata.*)!
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
Martin Landa wrote:
> Added:
> Modified:
> Log:
The code in menudata.py which reads the XML passes the various fields
through the _(...) function, so the existing translations should be
used.
In terms of obtaining the strings to create the .pot files, I'll add
some code to generate a dummy .py file for use by gettext.
