neteler
December 16, 2008, 5:18pm
1
On Tue, Dec 16, 2008 at 3:33 PM, <svn_grass@osgeo.org> wrote:
Date: 2008-12-16 09:33:27 -0500 (Tue, 16 Dec 2008)
New Revision: 34913
Modified:
grass/branches/develbranch_6/general/g.gisenv/main.c
Log:
g.gisenv: -s/n flags added (merge from trunk)
+ flag_s = G_define_flag();
+ flag_s->key = 's';
+ flag_s->description = _("Use shell syntax (for \"eval\")");
+ flag_n = G_define_flag();
+ flag_n->key = 'n';
+ flag_n->description = _("Don't use shell syntax");
Is -n really needed?
GRASS 6.4.svn (spearfish60): > g.gisenv
GISDBASE=/home/neteler/grassdata
LOCATION_NAME=spearfish60
MAPSET=neteler
DEBUG=0
GRASS_GUI=text
GRASS 6.4.svn (spearfish60): > g.gisenv -s
GISDBASE='/home/neteler/grassdata';
LOCATION_NAME='spearfish60';
MAPSET='neteler';
DEBUG='0';
GRASS_GUI='text';
GRASS 6.4.svn (spearfish60): > g.gisenv -n
MAPSET=neteler
DEBUG=0
GRASS_GUI=text
Isn't -n superfluous?
> New Revision: 34913
> Modified:
> Log:
Yes.
MAPSET=neteler
DEBUG=0
GRASS_GUI=text
MAPSET='neteler';
DEBUG='0';
GRASS_GUI='text';
MAPSET=neteler
DEBUG=0
GRASS_GUI=text
No.
$ g.gisenv
GISDBASE=/opt/grass-data
LOCATION_NAME=spearfish57
MAPSET=glynn
GRASS_GUI=text
$ g.gisenv | cat
GISDBASE='/opt/grass-data';
LOCATION_NAME='spearfish57';
MAPSET='glynn';
GRASS_GUI='text';
$ g.gisenv -n | cat
MAPSET=glynn
GRASS_GUI=text
With neither -s nor -n, the default is -n if stdout is a tty and -s
otherwise (e.g. if stdout is a pipe).
The -n switch is necessary if you're parsing the g.gisenv output
within a script, and you want the "simple" format (i.e. if you're not
using bash's "eval" for parsing).
