[GRASS-dev] Re: [GRASS-SVN] r36342 - grass/trunk/raster/r.los
On Thu, Mar 12, 2009 at 12:33 PM, <svn_grass@osgeo.org> wrote:
Author: glynn
Date: 2009-03-12 07:33:40 -0400 (Thu, 12 Mar 2009)
New Revision: 36342
Modified:
grass/trunk/raster/r.los/main.c
grass/trunk/raster/r.los/point.h
Log:
Fix compilation error due to r36161/r36181; 7.0 doesn't abuse the preprocessor
A backport candidate?
Markus Neteler wrote:
> Author: glynn
> New Revision: 36342
> Modified:
> Log:
There was a large change which removed all of the "#ifdef MAIN" usage
in 7.0. If you aren't going to backport all of it, there probably
isn't much point doing isolated cases.
