is it really needed in trunk in regards we are planning to
use Python for all scripts?
AFAIK it is needed whenever non-.exe or .bat named modules will be run
using simply their command name. So that is needed for both python and
shell scripts. Windows doesn't know executable bits or #!/bin/python
shebangs. The alternative is to add interpreters and path names to the
command line, and change all script's GUI menu entries to some special
launch function.
launch function.
It should only be needed for Tcl/Tk (exec and "open |..."), which has
its own hacks for .exe and .bat (maybe .com and/or .cmd? I'm not
sure).
Everything other than Tcl/Tk falls into one of two cases: either you
always have to provide the extension (even for .exe or .bat), or it
uses PATHEXT and the registry settings (related to ftype/assoc).
BTW, we need to add .py to PATHEXT; we don't appear to be doing this
at present.
