On Tue, Jan 19, 2010 at 4:41 PM, <svn_grass@osgeo.org> wrote:
Author: glynn
Date: 2010-01-19 10:41:38 -0500 (Tue, 19 Jan 2010)
New Revision: 40554
Modified:
grass/trunk/raster/r.in.bin/main.c
Log:
Fix segfault with -d and anull=...
Modified: grass/trunk/raster/r.in.bin/main.c
--- grass/trunk/raster/r.in.bin/main.c 2010-01-19 11:46:59 UTC (rev 40553)
+++ grass/trunk/raster/r.in.bin/main.c 2010-01-19 15:41:38 UTC (rev 40554)
@@ -555,7 +555,11 @@
cell[col] = (CELL) (unsigned int)x_i[col];
if (parm.anull->answer) {
- if (flag.f->answer) {
+ if (flag.d->answer) {
+ if (dcell[col] == nul_val)
+ Rast_set_d_null_value(&dcell[col], 1);
+ else if (flag.f->answer) {
if (fcell[col] == (float)nul_val)
Rast_set_f_null_value(&fcell[col], 1);
Should this be backported with G_set_[f|d]_null_value()?
Markus Neteler wrote:
> Author: glynn
> New Revision: 40554
> Modified:
> Log:
Yes; the 'c' and 'f' cases are already there; this adds the 'd' case.
neteler
3
On Wed, Jan 20, 2010 at 7:33 AM, Glynn Clements
> Author: glynn
> New Revision: 40554
> Modified:
> Log:
Done.
