Colin,
is this to be backported?
On Fri, Apr 2, 2010 at 12:14 AM, <svn_grass@osgeo.org> wrote:
Author: cnielsen
Date: 2010-04-01 18:14:53 -0400 (Thu, 01 Apr 2010)
New Revision: 41653Modified:
grass/trunk/raster/r.drain/main.c
grass/trunk/raster/r.drain/r.drain.html
Log:
Missing inits caused infinite loopModified: grass/trunk/raster/r.drain/main.c
--- grass/trunk/raster/r.drain/main.c 2010-04-01 21:28:05 UTC (rev 41652)
+++ grass/trunk/raster/r.drain/main.c 2010-04-01 22:14:53 UTC (rev 41653)
@@ -642,7 +642,7 @@
* read next. This is repeated via a while loop until a null direction is found.
*/- int neighbour, next_row, next_col, go = 1;
+ int neighbour, row, col, next_row, next_col, go = 1;
DCELL direction;
DCELL *dir_buf;Modified: grass/trunk/raster/r.drain/r.drain.html
--- grass/trunk/raster/r.drain/r.drain.html 2010-04-01 21:28:05 UTC (rev 41652)
+++ grass/trunk/raster/r.drain/r.drain.html 2010-04-01 22:14:53 UTC (rev 41653)
@@ -162,8 +162,8 @@
according to one of the <b>-can</b> flags.
<div class="code"><pre>
The directions are recorded as GRASS standard directions:
- 112.5 90 67.5 i.e. a cell with the value 135
-157.5 135 0 45 22.5 means the cell <b>before</b> it is
+ 112.5 67.5 i.e. a cell with the value 135
+157.5 135 90 45 22.5 means the cell <b>before</b> it is
180 x 0 to the south-east.
202.5 225 270 315 337.5
247.5 292.5_______________________________________________
grass-commit mailing list
grass-commit@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/grass-commit
