2010/8/26 <svn_grass@osgeo.org>:
Author: hamish
Date: 2010-08-26 05:44:50 +0000 (Thu, 26 Aug 2010)
New Revision: 43273Modified:
grass/trunk/scripts/m.proj/m.proj.py
Log:
option not req'd as a default answer existsModified: grass/trunk/scripts/m.proj/m.proj.py
--- grass/trunk/scripts/m.proj/m.proj.py 2010-08-25 21:38:35 UTC (rev 43272)
+++ grass/trunk/scripts/m.proj/m.proj.py 2010-08-26 05:44:50 UTC (rev 43273)
@@ -35,7 +35,6 @@
#% gisprompt: old_file,file,file
#% description: Input coordinate file ('-' to read from stdin)
#% answer: -
-#% required : yes
#% key_desc : filename
#% guisection: Files & format
#%end
stdin default is quite problematic from GUI perspective. I would suggest
#% label: Input coordinate file
#% description: '-' to read from stdin
#% required : yes
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
