[GRASS-dev] Re: [GRASS-SVN] r44857 - grass/trunk/lib/vector/diglib
the commit seems to be incomplete
martin@pierre:~/src/grass_trunk/lib/vector/diglib$ make
gcc -g -Wall -Werror-implicit-function-declaration -fno-common
-Wextra -Wunused -fPIC
-I/usr/local/src/grass_trunk/dist.i686-pc-linux-gnu/include
-D_FILE_OFFSET_BITS=64 -I/usr/local/include -I/usr/local/include
-DPACKAGE=\""grasslibs"\"
-I/usr/local/src/grass_trunk/dist.i686-pc-linux-gnu/include -o
OBJ.i686-pc-linux-gnu/spindex.o -c spindex.c
OBJ.i686-pc-linux-gnu/type.o -c type.c
OBJ.i686-pc-linux-gnu/update.o -c update.c
spindex.c: In function ‘dig_spidx_init’:
spindex.c:43: error: ‘struct Plus_head’ has no member named ‘Spidx_file’
make: *** [OBJ.i686-pc-linux-gnu/spindex.o] Error 1
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
On Tue, Jan 4, 2011 at 11:17 AM, Martin Landa <landa.martin@gmail.com> wrote:
Should be fixed in r44862. (You were faster updating than I was committing;-))
Martin
2011/1/4 Markus Metz <markus.metz.giswork@googlemail.com>:
thanks, Martin
