2011/1/14 <svn_grass@osgeo.org>:
Author: benducke
Date: 2011-01-14 13:04:44 -0800 (Fri, 14 Jan 2011)
New Revision: 45036
Modified:
grass/branches/develbranch_6/vector/v.out.ogr/main.c
Log:
This commit contains some small bugfixes, code clean-ups and two new feature for v.out.ogr.
1. Fixed a but that would spawn ugly error messages in conjunction with the "-s" flag
2. Reduced the SQL SELECT statements to just one instead of one per feature, increasing output speed by several magnitudes.
3. Added a new "-z" flag, which provides a simple and robust means of producing 3D ESRI Shapefiles
--> Please test intensively!
please, could you use trunk as development branch and optionally
backport the changes to devbr6? Devbr6 is intended to be a test-bed
for relbr64 backports! Go for GRASS 7!
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
OK, committed to and test in GRASS 7.
All seems to work smoothly as far as I can tell, but please test.
Note that I have also implemented the "-z" flag for easy
production of 3D Shapefiles. Also tested that and can see no
problems so far.
I would really like to see those changes in GRASS 6.4.2 at the
latest, though. They do make my life a lot easier.
Ben
----- Original Message -----
> Author: benducke
> New Revision: 45036
> Modified:
> Log: This commit contains some small bugfixes, code clean-ups and
> with the "-s" flag
Martin
-- Martin Landa <landa.martin gmail.com> *
Files attached to this email may be in ISO 26300 format (OASIS Open Document Format). If you have difficulty opening them, please visit http://iso26300.info for more information.
