martinl
1
2011/9/6 <svn_grass@osgeo.org>:
Author: mmetz
Date: 2011-09-05 23:48:56 -0700 (Mon, 05 Sep 2011)
New Revision: 48158
Modified:
grass/branches/releasebranch_6_4/db/drivers/sqlite/create_table.c
grass/branches/releasebranch_6_4/db/drivers/sqlite/cursor.c
grass/branches/releasebranch_6_4/db/drivers/sqlite/db.c
grass/branches/releasebranch_6_4/db/drivers/sqlite/describe.c
grass/branches/releasebranch_6_4/db/drivers/sqlite/driver.c
grass/branches/releasebranch_6_4/db/drivers/sqlite/error.c
grass/branches/releasebranch_6_4/db/drivers/sqlite/execute.c
grass/branches/releasebranch_6_4/db/drivers/sqlite/fetch.c
grass/branches/releasebranch_6_4/db/drivers/sqlite/index.c
grass/branches/releasebranch_6_4/db/drivers/sqlite/listtab.c
grass/branches/releasebranch_6_4/db/drivers/sqlite/main.c
grass/branches/releasebranch_6_4/db/drivers/sqlite/proto.h
grass/branches/releasebranch_6_4/db/drivers/sqlite/select.c
Log:
sqlite driver: fix for #548 and related
SQLITE_IOERR_BLOCKED is not defined in older Sqlite versions (e.g.
3.3.8). Hopefully fixed in r48167.
Martin
BTW: trunk is no affected...
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
On Tue, Sep 6, 2011 at 5:57 PM, Martin Landa <landa.martin@gmail.com> wrote:
Author: mmetz
New Revision: 48158
Modified:
Log:
Thanks! I have simplified usage of the sqlite busy handler, no more
#if ... #else needed.
Markus M
martinl
3
2011/9/7 Markus Metz <markus.metz.giswork@googlemail.com>:
Thanks, Martin
