Stepane,
2012/4/12 <svn_grass@osgeo.org>:
Author: turek
Date: 2012-04-11 15:45:34 -0700 (Wed, 11 Apr 2012)
New Revision: 51384
Modified:
grass-addons/grass7/raster/r.in.wms2/r.in.wms2.html
Log:
r.in.wms2.html: examples which does not worked were removed
to vypada, ze nefungovalo temer nic, chtelo by zjistit proc a
nefunkcni priklady nahradit fungujicimi (vice wms serveru nez CUZK
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
ops, sorry for internal communication in Czech. Probably I am a little
bit overworked and should go finally to sleep So I will translate
the text bellow...
2012/4/12 Martin Landa <landa.martin@gmail.com>:
seems to me that none of examples did not work with `r.in.wms2`. It
would be better to find out why they didn't work and to replace them
with working examples, not just to remove them. One working example
(CUZK) is probably not enough
Martin
All removed examples used service[1], which no longer provides standard WMS access.
I will try to add more examples.
Stepan
[1] http://onearth.jpl.nasa.gov/
---------- Původnà zpráva ----------
Od: Martin Landa landa.martin@gmail.com
Datum: 12. 4. 2012
Předmět: [GRASS-dev] Re: [GRASS-SVN] r51384 - grass-addons/grass7/raster/r.in.wms2
the text bellow…
2012/4/12 Martin Landa landa.martin@gmail.com:
seems to me that none of examples did not work with r.in.wms2
. It
would be better to find out why they didn’t work and to replace them
Martin
grass-dev mailing list
grass-dev@lists.osgeo.org
