[GRASS-dev] Re: GRASS Test suite
Hi Anne,
i will put the GRASS test suite implementation discussion on the dev
list if you don't mind? :slight_smile:
A segfault should not happen. All tests run on my systems very well
(latest grass7, openSuse 11.2).
Do you use the latest grass7 trunk? Can you please use gdb to hunt
down the error, i will fix it.
I use GRASS 7 r 46894, compiled this morning, on Fedora 14 64bit.
`r3.colors -e map=volume_double_null rules=example1`
this command segfaults at raster/r.colors/stats.c, line 155, with
invalid pointer:
G_free(dcell);
Markus looked at the problem and suggested this patch, line 150:
if (type == RASTER_TYPE) {
Rast_close(fd);
G_free(dcell);
(sorry for patch format but it's such a tiny modification)
Many thanks for the patch, i have committed your solution to svn. Good
to have some tests. :slight_smile:
I see that in the wiki the part about Python has been removed, which
parts of the system we drafted in Prague are still valid?
Not much. :slight_smile:
I'm fine with setting up the Python part of the framework. I fear that
as I'm not familiar with makefiles, it's better to ask Glynn and the dev
list for guidance too.
I have updated the wiki with more implementation details for the
Python test framework:
http://grass.osgeo.org/wiki/Test_Suite#Implementation
This is just a very draft concept but it hopefully shows the
implementation approach i have in mind. IMHO the implementation should
not be very complex, except the ability of the framework to act as a
simple shell.
Regarding the Make system: unfortunately i am not familiar with
Makefile handling too, so i am no help on this topic.
Should we move the wiki page to the new trac wiki or can we leave it
in the old? I would suggest to move ... .
Best regards
Soeren
can we move the test files into $MODULE/testsuite/ or similar?
I'm just looking at grass7/raster/r.colors/ and the test files
really dominate the module dir.
thanks,
Hamish
Le dimanche 03 juillet 2011 à 15:53 -0700, Hamish a écrit :
+1 from me on having a testsuite/ or tests/ subdir for each module.
I'm starting to implement the test framework, it will be in
trunk/testsuite. Hints on how to modify the Makefile are welcome!
best,
Anne
2011/7/4 Anne Ghisla <a.ghisla@gmail.com>:
also +1 from me.
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
2011/7/4 Martin Landa <landa.martin@gmail.com>:
also +1 from me.
The directory layout has been discussed here:
http://osgeo-org.1803224.n2.nabble.com/Test-suite-for-GRASS-proposal-discussion-welcome-td6391218.html
I would suggest to either use reference_data/ subdir for each module,
so that the test scripts may stay in the module directory, not in a
subdirectory, or a testsuite/ subdir including all data?
I personally prefer a reference data subdir, to have a clear
separation of test case scripts and reference data. Otherwise the
reference data will dominate again and finding the test scripts is not
that obvious.
Best regards
Sören
Martin
grass-dev mailing list
grass-dev@lists.osgeo.org
Hi Anne,
Thank you for starting the implementation. If you have any tiny
question, don't bother to ask. I hope the whole test suite picture
comes much clearer when some basic framework is available to play
around a with.
Important: in case the test script approach which i have used for the
test cases in the g3d modules is not sufficient, i will modify them to
fit the new guidelines and insights.
Best regards
Soeren
best,
Anne
Le lundi 04 juillet 2011 à 10:52 +0200, Soeren Gebbert a écrit :
> Hi,
> also +1 from me.
that obvious.
In the case of r.colors, there are a lot of .ref files and one .sh
script, that is hidden among them when the folders contents are ordered
alphabetically. I haven't checked if it will be the case of other
modules.
Personally I prefer to keep all test data and scripts together in the
tests/ subfolder.
But if the majority find it uncomfortable as the script file is less
accessible, let's keep it in module folder and put data in the subfolder
(after correcting the paths in script file).
Opinions?
regards
Anne
Best regards
Sören
> Martin
Hello Anne,
> Hi,
> also +1 from me.
that obvious.
modules.
This is the case for most modules with tests applied:
http://trac.osgeo.org/grass/browser/grass/trunk/raster3d/r3.out.ascii
http://trac.osgeo.org/grass/browser/grass/trunk/raster3d/r3.cross.rast
http://trac.osgeo.org/grass/browser/grass/trunk/raster3d/r3.retile
http://trac.osgeo.org/grass/browser/grass/trunk/raster3d/r3.stats
http://trac.osgeo.org/grass/browser/grass/trunk/raster3d/r3.to.rast
http://trac.osgeo.org/grass/browser/grass/trunk/raster/r.to.rast3elev
tests/ subfolder.
Opinions?
The paths used in the test scripts should not be affected by the
location of the reference files. Only the framework and the test
designer need to know that. The user/dev who implements the tests must
assure that the reference files are located in the reference
directory. The framework than take care that while testing generated
files are compared with the reference files located in the reference
directory.
Hmmmm, ... i think the test scripts should always write any ascii file
output in the current working directory, so the framework can execute
the tests in a temporary directory which can be removed for clean up
after reference data validation. I will add this to the wiki.
Lets keep for practical reason the test scrip in the module directory
and add a "test_reference_data" or "test_refs" directory to the module
directory keeping the reference data.
Best regards
Sören
