Markus Neteler wrote:
Maciej Sieczka wrote on 08/03/2007 12:21 PM:
Ravi, are you referring to the fact that there is no generic 32bit
binary GRASS package on GRASS website, but only 64bit?
If so, I don't know how to generate 32bit binaries on a (pure) 64bit
machine as the GRASS server is. A way out would be that a community
member auto-generates 32bit Linux binaries which I then auto-fetch
every week.
Hi
After some reading I must say I'm to ignorant in this regard and won't
help much. If anybody is willing to take on this, I found 2 usefull
resources: "building 32bit app on 64bit system" [1] and "How to build
32-bit Wine on a 64-bit (x86-64) system" [2]. The latter is about Wine,
but it gives detailed instructions for several main distributions,
which could help.
[1]http://www.linuxquestions.org/questions/showthread.php?t=570955
[2]http://wiki.winehq.org/WineOn64bit
Maciek
> every week.
Hi
which could help.
export CFLAGS="-m32..."
However, I fail to see the usefulness of 32bit GRASS on 64bit systems.
Brad Douglas <rez touchofmadness com> KB8UYR/6
Address: 37.493,-121.924 / WGS84 National Map Corps #TNMC-3785
every week.
Hi
which could help.
The question was whether Markus could use his 64bit server to cross-compile binaries for 32bit systems or whether someone with a 32bit system would have to do it.
Moritz
>>> every week.
>> Hi
>> which could help.
Ah. Okay, I misunderstood the question. Yes, it is possible to compile
32bit on 64bit. I don't do it simply because I hate to co-mingle bit
depths, but that's a personal choice.
