imho this could be reason for $HOME/.grass6/7 directory
also configuration files from r.li should go there..
we would need set of functions, which whould identify & open the
configuration files, if they would exist...
what do you think, developers?
jachym
2007/3/19, Jaros³aw Jasiewicz <jarekj@amu.edu.pl>:
Hi
I have a suggestion about color managment in grass
I just work on couple of maps where I need to prepare custom color
schemes (rules). Using the r.colors.rules is slighty (Hmm... rather
strongly) uncomfortable.
To omit it I replaced dir colors in ../grass63.cvs/etc/ dir with simlink
to dir in my home directory and I create new rule file every time I must
experiment with colors.It is not good solution for two reason:
1) every new grass complilation makes problem with symlink
2) I have over 60 rules files in one directory and the number increaseIs possible to create solution similar to r.reclass.file to use custom
color rule file from anywhere in file system?regards
Jarek_______________________________________________
grassuser mailing list
grassuser@grass.itc.it
Jachym Cepicky
e-mail: jachym.cepicky gmail com
URL: http://les-ejk.cz
GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
