[GRASS-dev] Re: [GRASS-user] 'ARNing: Cannot open driver 'dbf"
Hamish:
> Can anyone else copy vector maps in windows?
Markus:
in manage/lib/do_copy.c, 'mkdir' is used which IMHO needs a special
treatment on Windows. See for example lib/gis/mapset_msc.c
here I leave this bug- I leave Windows developement as a challenge for
others to pursue.
Hamish
Hamish wrote on 12/07/2006 09:28 AM:
Hamish:
Markus:
others to pursue.
There are some candidates for this fix (contains some false positives):
find . -type f -name "*.c" -exec grep -l mkdir {} \;
./general/manage/lib/do_copy.c
./raster/r.li/r.li.daemon/daemon.c
./raster/r.le/r.le.setup/main.c
./raster/r.le/r.le.patch/main.c
./raster/r.le/r.le.pixel/main.c
./lib/init/mke_mapset.c
./lib/init/mke_loc.c
./lib/db/dbmi_driver/d_mkdir.c
./lib/gis/make_mapset.c
./lib/gis/make_loc.c
./lib/gis/mapset_msc.c
./lib/gis/win32_pipes.c
./lib/gis/unix_socks.c
./lib/gis/paths.c
./lib/gis/user_config.c
./lib/raster/io_fifo.c
./lib/g3d/g3dwindowio.c
./gem/reg_entries.c
./gem/actions.c
lib/gis/paths.c
Probably a search/replace of ' mkdir' would do, using G_mkdir() from
./lib/gis/paths.c
? Or we need to modify G_mkdir() to accepts two parameters.
> others to pursue.
./lib/gis/paths.c
./gem/reg_entries.c
./gem/actions.c
lib/gis/paths.c
./lib/gis/paths.c
No, G_mkdir() is fine.
On Unix, the mode argument should always be 0777, so the user has
complete control of the permissions via their umask; anything which
uses a more restrictive mode is second-guessing the user.
The only programs which should be setting permissions explicitly are
those which provide some other mechanism for the user to control the
permissions.
> ./lib/gis/paths.c
permissions.
I have done the changes to G_mkdir() accordingly.
Also added a G_lstat() in lib/gis/paths.c for a similar
problem.
Find attached a diff for review.
The following 3 functions are too complicated for me (!)
to fix:
G_mkdir TODOS:
Feedback welcome,
(attachments)
G_mkdir.diff (8.62 KB)
> > ./lib/gis/paths.c
> permissions.
problem.
to fix:
G_mkdir TODOS:
The only code here which uses mkdir() is commented out.
I'm currently testing the attached patch.
Can't we just kill this? I don't even know if it still works, given
that almost no-one actually uses --enable-fifo.
In any case, I doubt that file will work on Windows.
(attachments)
mkdir-stat.diff (2.67 KB)
> to fix:
I'm surprised I managed to make so many mistakes for such a relatively
small change. I've attached an updated patch; apart from eliminating
the compilation errors, it eliminates the warnings arising from the
addition of G_lstat().
(attachments)
mkdir-stat.diff (3.06 KB)
However, photo.elev fails to compile due to a conflicting use of
"stat" in elev.h.
In retrospect, this is probably sufficient (and less problematic):
--- include/gisdefs.h 13 Dec 2006 16:48:41 -0000 1.74
+++ include/gisdefs.h 13 Dec 2006 22:57:17 -0000
@@ -870,6 +870,7 @@
int G_is_dirsep(char);
char *G_convert_dirseps_to_host(char *);
char *G_convert_dirseps_from_host(char *);
+struct stat;
int G_lstat(const char *, struct stat *);
/* percent.c */
Glynn Clements wrote on 12/13/2006 11:58 PM:
"stat" in elev.h.
@@ -870,6 +870,7 @@
+struct stat;
/* percent.c */
Thanks Glynn. So should I submit the other changes then?
I have now submitted the G_mkdir() and G_lstat() changes.
Hopefully a help for portability.
If we don't need it, let's remove it. Unused code is only
confusing.
confusing.
just for curiosity, what's the (dis)advantage of using FIFO vs sockets?
Hamish
> confusing.
Ugly code, not particularly robust, needs a global mode 1777
(world-writable, sticky-bit) directory for lock files (and thus the
need to deal with stale lock files), need to pre-create the FIFOs.
Also the need to store their paths in etc/monitorcap, which means
modifying it if you move the GRASS installation:
http://grass.itc.it/pipermail/grass-dev/2003-February/007083.html
[Currently, we store relative paths, which don't actually work.]
The "obvious" mechanism for client-server communication is a socket.
The FIFO code existed for systems which don't have sockets. Nowadays,
such systems are about as common as 8-inch floppies or punched cards.
I only know of one person (Bev Wallace) who was actually using the
FIFO option, and that appears to be no longer relevant:
http://grass.itc.it/pipermail/grass-dev/2003-February/007095.html
