Glynn Clements wrote:
Hamish wrote:
> > Note that setting the environment variables:
> > GRASS_NO_GLX_PBUFFERS
> > GRASS_NO_GLX_PIXMAPS
> > will disable use of these features, in case of problems with your
> > OpenGL setup (libraries or X server). Their values don't matter, only
> > whether or not they are set.
> These should be added to lib/init/variables.htmlI'll do that.
> Setting those make no difference to this bug however:
> #with GLX
> G63 > nviz elevation.10m> % Creating PBuffer Using GLX 1.3
> Create PixMap Using GLX 1.1> Final Assembled Image will be 1929 x 2048
> Assembling Tiles
> pnmcat: EOF / read error reading a row of pixels> #without GLX
> G63> export GRASS_NO_GLX_PBUFFERS=TRUE
> G63> export GRASS_NO_GLX_PIXMAPS=TRUE
> G63> nviz elevation.10m> % Final Assembled Image will be 1904 x 2048
> Assembling Tiles
> pnmcat: Zero byte allocationWell, it appears to make *some* difference, i.e. you're getting a
different error message.Does removing the following from nviz2.2_script help?
# Set the cancel function for drawing
Nset_cancel_func update
nope. I tried that yesterday (without GRASS_NO_GLX_*), have just tried
again with that commented out + GRASS_NO_GLX_* set. It's still broken.
Writing Tile 8 of 9
Writing Tile 9 of 9
Assembling Tiles
pnmcat failed to create assembled image
Check that pnmcat is installed and path is set
pnmcat: EOF / read error reading magic number
pnmcat failed to create assembled images
adding some G_debug(0,) messages to lib/ogsf/gsd_prim.c to check on
the *pixbuf = malloc(xsize * ysize * 4);
% Final Assembled Image will be 2048 x 2048
Writing Tile 1 of 9
D0/0: gsd_writeView(): xsize=1024 ysize=1024
Writing Tile 2 of 9
Writing Tile 3 of 9
D0/0: gsd_writeView(): xsize=0 ysize=1024
Writing Tile 4 of 9
Writing Tile 5 of 9
Writing Tile 6 of 9
Writing Tile 7 of 9
D0/0: gsd_writeView(): xsize=1024 ysize=0
Writing Tile 8 of 9
Writing Tile 9 of 9
D0/0: gsd_writeView(): xsize=0 ysize=0
Assembling Tiles
the img_width, img_height are reset to 0 in nviz/src/do_zoom.c line ~128:
/* Re-set image width or height if required */
if ((maxx + XX) < c)
img_width = maxx + XX;
if ((maxy + YY) < d)
img_height = maxy + YY;
Hamish
