[GRASS-dev] Re: [GRASS-user] bug in v.db.renamecol
Markus Neteler wrote:
http://trac.osgeo.org/grass/changeset/30007
+ # strangely "" counts as 1
+ NAMELEN=`echo "$newcol" | wc -c | awk '{print $1}'`
+ if [ "$NAMELEN" -gt 11 ] ; then
the extra char is due to the newline:
$ echo "" | wc -c
1
$ echo -n "" | wc -c
0
For v.db.renamecol + SQLite and DBF, should we add extra checks like
'v.info -c' or even compare before/after v.db.select counts to check
that new column is there and contains data before calling v.db.dropcol?
I guess it's a matter of paranoia vs. wasted redundant effort how far
you go with that.
Hamish
      ____________________________________________________________________________________
Looking for last minute shopping deals?
Find them fast with Yahoo! Search. http://tools.search.yahoo.com/newsearch/category.php?category=shopping
$ echo "" | wc -c
1
0
ah, right.
Question: is "-n" portable? I darkly remember some issue.
you go with that.
Hamish
Markus Neteler <neteler@osgeo.org> writes:
>> $ echo "" | wc -c 1 $ echo -n "" | wc -c 0
> ah, right. Question: is "-n" portable? I darkly remember some issue.
  It's mandated by POSIX at least [1]. Besides, it's already used
  widely in the GRASS scripts:
grass $ grep -rF '[ -n ' scripts/
... numerous...
grass $
  One may also use [ x"$varn" != x ] instead, but I'd be against
  such a practice (unless for a good reason.)
[1] http://www.opengroup.org/onlinepubs/009695399/utilities/test.html
