[GRASS-dev] Re: [GRASS-user] Calling GRASS scripts from GRASS C modules
2011/3/23 Glynn Clements <glynn@gclements.plus.com>:
If you need to communicate via a pipe, you can either use G_spawn_ex()
and manage the pipe yourself (see lib/db/dbmi_client/start.c for an
example), or use popen(). Don't use G_popen(); the Unix version is
practically the same as popen() anyhow, and the Windows version is
completely broken.
I took a liberty to put your very useful notes to API manual (r45736).
Please feel free to correct it if needed.
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
