2008/8/5 christian Brandt <chrisbrandt74@hotmail.com>:
I try to adapt the color table of a raster file using an ascii file (> rules option) with the following statement:
r.colors map=b25_daymax0.l1_neu@PERMANENT color=rules 'rules=/sonne3/.../GIS/colorscript_farben_temp'
Hence the following message comes up:
"color", "rules", and "raster" options are mutually exclusive
Any ideas what this means? Please see also the attached colorscript.
it seems to be a bug in r.colors, the attached patch quickly fix it.
Anyway r.colors needs some more cleaning. In GRASS7 I would suggest to
remove
-i Enter rules interactively
1) then if rules file is given read from the file
2) if not given (and color=rules) switch to the interactive mode
3) or completely remove interactive mode, print error about missing
rules file <- seems to be a better solution, to avoid any interactive
mode in GRASS7
Martin
[cc: grass-dev, sorry for cross-posting)
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
(attachments)
r-colors-rules-fix.diff (1.49 KB)
