[GRASS-dev] Re: [GRASS-user] Error while creating vectorial file in WinGRASS
Hamish wrote:
You need to run db.connect to select a database backend to
use first. (There is no VAR file in the mapset yet)
hopefully fixed & ready for testing in 6.5svn r42988 (v.edit).
devs:
maybe do this for 'v.in.ascii -e' and 'v.digit -n' too?
or move this into Vect_open_new() ? ... but I'm not totally
convinced that's the right place for it either; the mapset may
come from an earlier version of GRASS. perhaps db.execute
instead of exiting with an error.
#include <grass/dbmi.h>
  if (! db_get_default_driver_name() ) {
      G_message(_("Creating new DB connection based on default mapset settings..."));
      db_set_default_connection();
see bug #7 http://trac.osgeo.org/grass/ticket/7
Hamish
devs:
Not to Vect_open_new(), a GRASS vector does not need to have a DB
connection, this is optional.
Markus M
Hamish
grass-user mailing list
grass-user@lists.osgeo.org
Hi there
Regarding Hamish suggestion "
You need to run db.connect to select a database backend to use
The thing is: I have been using an WinGRASS6.4 binary version where I didn’t need to do anything else. Just create Vector by doing this. So, my question is, why was this disabled? Or is it some error that only occurs in this release?
About
Will it be available for 6.4 in Windows?
Thanks
Kim
2010/8/4 Markus Metz <markus.metz.giswork@googlemail.com>
devs:
maybe do this for ‘v.in.ascii -e’ and ‘v.digit -n’ too?
Markus M
… but I’m not totally
convinced that’s the right place for it either; the mapset may
G_message(_(“Creating new DB connection based on default mapset settings…”));
Hamish
