is there anybody who has *no* problem with g.gisenv variable DEBUG?? I
have, I was trying to find out why... I have found a strange problem
in function
After reading the first line in read_env() [env.c], the function
G_debug () is called, it cause that (see debug.c) grass_debug_level
variable is set to 0. As a result no debug message will be displayed
regardless to DEBUG value.
I don't know why, just trying to find out why no debug messages are
not displayed any more...
Best, Martin
2006/10/11, Hamish <hamish_nospam@yahoo.com>:
> > > .... no debug message, should be(?)
> > odd, same here.
> > g.gisenv set="DEBUG=5"
> > echo "1|1" | v.in.ascii out=foo
> > no debug messages!
> > It seems that lstr = G__getenv( "DEBUG" ); in lib/gis/debug.c
> > fails for some reason (lstr gets set to NULL).
> we discussed this with soeren (huhabla) on irc while ago with the
> result, that if the module is runing in gdb environment, debuging
> works
> i do not know why, but it was so :-/
