[CC to grass-dev]
Nikos Alexandris wrote:
# faster/ easier way: use of the "grass.region()" function
rows = int(grass.region()['rows'])
cols = int(grass.region()['cols'])
In 7.0, these fields are already integers; r40555 should be
backported.
On Mon, May 31, 2010 at 3:50 AM, Glynn Clements
<glynn@gclements.plus.com> wrote:
[CC to grass-dev]
\# faster/ easier way: use of the "grass\.region\(\)" function
rows = int\(grass\.region\(\)\['rows'\]\)
cols = int\(grass\.region\(\)\['cols'\]\)
backported.
AFAIK it has been backported some time ago.
http://trac.osgeo.org/grass/browser/grass/branches/releasebranch_6_4/lib/python/core.py#L503
> backported.
Okay; change that to "I should 'svn update' the other branches more
often", then
> > backported.
> python/core.py#L503
often", then
This means it should be like:
rows = grass.region()['rows']
cols = grass.region()['cols']
Right?
Nikos
> > > backported.
> > python/core.py#L503
> often", then
Right?
Right; although you should store the result of grass.region() to avoid
redundant g.region commands, i.e.:
rgn = grass.region()
rows = rgn['rows']
cols = rgn['cols']
Glynn:
> > > > backported.
Markus:
> > > lib/ python/core.py#L503
Glynn:
> > often", then
Nikos:
> Right?
rows = rgn['rows']
cols = rgn['cols']
Is python's "int()" truncating or rounding up values? The question came to me
while thinking of r.mapcalc's respective functions ( i.e. "int() != round()" )
Nikos
In this case, neither; it's just converting strings to integers. The
rows and cols values in the g.region output will always be integers.
If you pass a floating-point value to int(), it will be truncated
(i.e. rounded towards zero):
> int(1.9)
1
> int(-1.9)
-1
If you pass a string containing a decimal point to int(), it will
raise an exception:
> int("1.9")
File "<stdin>", line 1, in <module>
ValueError: invalid literal for int() with base 10: '1.9'
> to me while thinking of r.mapcalc's respective functions ( i.e. "int()
> != round()" )
Right... needles question (=I need to rest a bit).
> int(1.9)
1
> int(-1.9)
-1
raise an exception:
> int("1.9")
Thanks for details, Nikos
