[GRASS-dev] Re: [GRASS-user] grass 6.4 rc5 and python scripting
> > In order for g.parser to work, the file teste.py needs to be in
> > your PATH.
Glynn wrote:
> This is actually a bug in G_parser() and G_gui(). menuform.py is
> being passed the base filename rather than the complete path.
> There isn't any other reason why the script needs to be in the
> path.
I've fixed this in 7.x with r38126. However, menuform.py
still tries to run the script using its basename.
should this be backported? if so, to which branches?
Hamish
> > > your PATH.
> > path.
It can't be merged directly, but similar changes should probably be
implemented in the other branches. But there isn't much point until
menuform.py is fixed.
2009/7/3 Glynn Clements <glynn@gclements.plus.com>:
I am not sure what should have been fixed. It's possible to launch a
script which is not in the PATH. The script must be executable, then
wxGUI is started properly.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
1. Create a script in the current directory, e.g.:
  #!/usr/bin/env python
  #%Module
  #% description: Test script.
  #%End
  #%option
  #% key: option
  #% type: string
  #% description: An Option
  #% required: yes
  #%END
  import sys
  from grass.script import core as grass
  def main():
      print options['option']
  if __name__ == "__main__":
      options, flags = grass.parser()
      main()
2. Run it with e.g. "./test.py --ui". It invokes g.parser which
invokes menuform.py with the full path to the script.
3. Fill in the option then click on the "Run" button. This results in
an error dialog:
  Execution failed: 'test.py option=foo'
  Details:
  Error: Unable to exectute command: 'test.py option=foo'
If you copy the script to a directory in $PATH, clicking the "Run"
button runs that script. This indicates that menuform.py is executing
the script using its basename, not the full path given as an argument.
2009/7/5 Glynn Clements <glynn@gclements.plus.com>:
OK, should be fixed in r38220 (trunk only).
Martin
