[GRASS-dev] Re: [GRASS-user] How choosing the colors of an imported map
On Aug 18, 2008, at 9:00 AM, <grass-user-request@lists.osgeo.org> wrote:
Date: Mon, 18 Aug 2008 18:05:54 +0300
From: Nikos Alexandris <nikos.alexandris@felis.uni-freiburg.de>
Subject: Re: [GRASS-user] How choosing the colors of an imported map
To: Paul Moen <pmoen@nd.gov>
Cc: grass-user@lists.osgeo.org
Message-ID: <1219071954.26438.11.camel@vertical>
Content-Type: text/plain
On Mon, 2008-08-18 at 09:34 -0500, Paul Moen wrote:
I am doing exactly that with the following script.
v.in.ascii input=textFile output=$RasName fs='tab' x=3 y=4 skip=0
cat=1
v.surf.rst input=RasName@Temp layer=1 zcolumn=dbl_3 tension=40. elev=
$RasName2 dmax=100 dmin=1
r.colors map=RasName@Temp color=arb-precip
Based on your commands RasName@Temp is a vector map and not a raster,
therefore r.colors won't work on it.
Your raster is the RasName2 map (output of v.surf.rst)
FYI, I just committed a new interactive color management module to the wxPython GUI code this weekend (in both develbranch_6 [GRASS 6.4] and trunk [GRASS 7]).
It allows you to set colors for rasters by entering cat values or percents and clicking a color chooser button. There is a preview window that allows you to fine tune your color table.
It also allows you to set colors for an rgb_column in vectors (areas only AIUI) by entering attribute values or ranges and clicking a color chooser button. The preview window also shows vector areas colored in this way for fine tuning.
Michael
Of course, your parameters for the commands above would be different
based on what you are importing.
arb-precip is a custom colormap that I created and placed in
$GIDBASE/etc/colors which looks like
-20 128 64 0
0.058823529 128 64 0
12.88235294 0 8 255
12.94117647 0 4 255
13 0 0 255
100 0 0 255
On 8/16/08 6:41 AM, "roberto caselli" <roberto.caselli@yahoo.it>
wrote:
       Hello everyone,
       I have an ascii file that I want to import using r.in.ascii to
       obtain a raster map. Is it possible to choose the colors of
       the ranges of the values in the ascii file?
       Roberto
Kind regards, Nikos
trunk [GRASS 7]).
Cool, very nice! I gave it a try in 6.4, seems to work great! Thanks for this feature,
~ Eric.
