[GRASS-dev] Re: [GRASS-user] How to remove nonexistent vector map
2011/9/5 Aren Cambre <aren@arencambre.com>:
I am trying to run v.in.ogr against a PostGIS database. The command's output
is:
ERROR: Vector map <pointdata> already exists
Yet when I run g.remove pointdata, I get:
Removing raster <pointdata>
Raster map <pointdata> not found
<pointdata> nothing removed
yes, this can be confusing for the user. I would vote to change this
behaviour (also for g.copy, g.rename). GRASS is for many years hybrid
GIS with strong vector-based tools. Noted modules in GRASS7 should
require option for defining element type, e.g.
g.remove pointdata
-> ERROR: You need define one of options <rast>, <rast3d>...
What do you think?
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
