[GRASS-dev] Re: [GRASS-user] i.cluster
Raphael Saldanha wrote:
I'm trying to run i.cluster, with WinGRASS 6.3.
The command: *i.cluster group=class@PERMANENT subgroup=cena1 sigfile=sig
classes=5 iterations=30 convergence=98.0 separation=0.0 min_size=17 *
But I'm having this error: *No such file or directory*
And, if I try some directory, like *i.cluster
group=class@PERMANENTsubgroup=cena1 sigfile=c:/sig classes=5
separation=0.0 min_size=17*
I have the error: *llegal filename. Character </> not allowed.*
So, what is the correct syntax to create the signature file?
This is a bug in i.cluster.
You'll need to use a filename without any drive or directory
component, e.g. "sigfile=sig".
[CC to grass-dev: fixed in r32766, recommend backporting.]
