[GRASS-dev] Re: [GRASS-user] improve v.rast.stats speed?
G. Allegri wrote:
Hello list.
Yesterday I needed to use v.rast.stats on a 1793 areas covering a
4415x6632 raster (with resolution 50m/pixel). I've used it without
extended statistics but the processing time was, with an euphemism,
very very long. After 5 hours it wasn't finished yet. As I needed it
for today morning I've decided to reproduce it with ArcGIS: 40
seconds. I've tried to investigate what was going wrong, the
bottleneck, but at the end I suppose that it's a problem of the script
itself (the looping chain of r.mapcalc and r.univar, the creation and
deletion of the MASK in each loop).
Is there any way to improve the performance of v.rast.stats? Should we
rewrite it in C and avoid the use of MASKs?
I have two ideas.
1) Use r.reclass instead of r.mapcalc to create new masks. That should speed up at least the MASK creation and deletion
2) Avoid the loop and MASK creation altogether. Run r.univar map=tmpname,raster. Process the output of r.univar, separate stats for the different vector areas and convert to sql statements. Proceed as before. r.univar would be called only once. I'm not sure if this is possible. I also don't know if the speed gain by avoiding the loop is annihilated by r.univar having to process two rasters as input.
cc-ing to the dev list
Markus M
