[GRASS-dev] Re: [GRASS-user] Installation problem
gotnidea! Business Development Centre wrote:
Thanks Moritz,
I could partially solve my problem with your help. I changed the c: option to d:.
But now, as you say, I can install GRASS on my C: with FAT32 structure, I am more interested in doing so. Earlier I had read at many places that GRASS could only work with NTFS.
Now to be precise, my problem with installation on C: (FAT32) starts while I install postgresql-8.1.4-1 and try to initialise database structure. I get data directory error telling me that data directory should be on NTFS formatted volume. It clearly mentions:
'If you wish to install the data directory on another type of partition (which is not recommended, and is unsupported) you must initialise the database cluster manually by running initdb.exe.'
How can I do so?
Can't you tell postgres where you want your data directory during the installation ? You could tell it to use your NTFS drive as data directory.
If this is not possible, then just follow their advice and use initdb.exe. See the postgresql docs for more info. But see below.
And how it is done. Would it affect the functioning of GRASS on FAT32?
You actually don't need postgresql to use GRASS, but the current windows binary was compiled against grass, so unfortunately you need the pg.dll to run any module. Even if you were not able to create a postgresql data directory during installation, you should still be able to run GRASS without any problems. Have you tried ?
The issue of the PostgreSQL dependency in wingrass was discussed here:
http://grass.itc.it/pipermail/grassuser/2006-September/036381.html
It seems clear that GRASS should not depend on PostgreSQL...
Moritz
Hi again
IIn my version of GRASS, I am unable to locate 'GIS' and 'Display' options in the menu. Nor am I able to generate any display in the Map display. It is totally blank!
I have followed all the steps given. How can I view the maps? I am working on Spearfish60 data with GRASS6.3 version on Windows Xp SP2.
I imagine you are following the tutorial for GRASS 6.0. The interface has changed since then with the passage from d.m (the Display Manager) to gis.m (the GIS Manager). In the latter there are no Display options in the menu as displaying is handled in individual monitors. Please read the description of the GIS Manager here:
http://grass.itc.it/grass63/manuals/html63_user/gis.m.html
I hope that someone will quickly integrate the GIS Manager into the tutorials...
Moritz
