On 6/19/08, Nikos Alexandris <nikos.alexandris@felis.uni-freiburg.de> wrote:
> > Thanks! Multiplying by 1000 with r.mapcalc gives better results. Any
> > chance adding floating points (FCELL) to i.cluster?
> I had a brief look at the code[1], and cannot see any obvious reason
> why the values would need to be integers, so I'm assuming that it's
> just a legacy of the days before FP support was added.
> [1] Most of the code is actually in the lib/imagery/c_*.c files. That
> should either be made part of i.cluster (nothing else uses it), or at
> least split into a separate library.
I have committed these changes (splitting the cluster code off to a
separate library, and changing it to use DCELL instead of CELL) to the
SVN trunk.
I would appreciate it if someone who understands i.cluster could test
the current version.
I've compiled and run it yesterday. How can I tell that the changes are
effective? Should i.cluster NOT work before the changes with FP maps?
From my previous run of i.cluster
Very low values like this:
r.info -r tcor.lsat7_2000.toar.1
min=0.039443
max=0.442334
Gives out low separability:
means and standard deviations for 3 bands
means 0.00 0.00 0.00
stddev 0.06 0.00 0.00
initial means for each band
class 1 -0.05 0.00 0.00
class 2 -0.05 0.00 0.00
class 3 -0.05 0.00 0.00
class 4 -0.05 0.00 0.00
class 5 -0.04 0.00 0.00
class 6 -0.04 0.00 0.00
class 7 -0.04 0.00 0.00
class 8 -0.04 0.00 0.00
class 9 -0.03 0.00 0.00
class 10 -0.03 0.00 0.00
1 classes (convergence=100.0%)
class separability matrix
1
1 0
class means/stddev for each band
class 1 (2161)
stddev 0.00 0.00 0.00
Whereas recalculating using the same layers multiplied by 1000 with
r.mapcalc gives better results:
means 316.19 82.61 -78.36
stddev 63.13 54.24 41.51
class 1 253.06 28.38 -119.87
class 2 255.64 30.59 -118.18
class 3 258.21 32.80 -116.49
class 4 260.79 35.02 -114.79
class 5 263.37 37.23 -113.10
class 6 265.94 39.44 -111.40
lass distribution
172 15 20 21 41
22 20 27 27 28
29 36 27 37 45
35 35 44 53 53
52 50 57 54 45
56 48 58 61 47
58 59 65 50 47
52 35 34 35 41
41 34 27 25 27
24 29 10 15 145
######## iteration 1 ###########
50 classes, 19.37% points stable
class distribution
60 45 19 98 10
18 71 13 8 112
176 8 10 15 7
6 9 23 124 22
8 53 13 125 134
10 14 10 52 8
101 12 19 39 45
12 4 178 119 11
8 11 29 77 18
Can you report back your results? I hope I dont have to do r.mapcalc
and run i.cluster from the original layer values.
cheers,
maning
grass-user mailing list
grass-user@lists.osgeo.org
| __.-._ |"Ohhh. Great warrior. Wars not make one great." -Yoda |
| '-._"7' |"Freedom is still the most radical idea of all" -N.Branden|
| /'.-c |Linux registered user #402901, http://counter.li.org/ |
| | /T |http://esambale.wikispaces.com|
| _)_/LI
