[GRASS-dev] Re: [GRASS-user] modify feature's values interactively
[moving this to -dev]
On 27/03/08 13:27, Hamish wrote:
Martin:
http://grass.gdf-hannover.de/wiki/Image:Wxgui-vector-querying-gnulinux.png
Moritz:
Cool !
However, I just can't get it to work:
I have
GRASS 6.3.svn (spearfish60):~ > v.db.connect -p roads
Vector map <roads@PERMANENT> is connected by:
Querying in display mode works as expected:
label : secondary highway, hard surface
But when I try to query it in edit mode, I get:
"No database record available"
just a guess: you were not in the PERMANENT mapset when you tried this
test? You can only edit maps in the current mapset (or at least that
should be the case) -- and the same is true for DBs.
If that is the problem here, I guess we need to add some more tests and
more appropriate error messages.
Nice guess, but that's unfortunately not it. I get the same message with:
GRASS 6.3.svn (spearfish60):~ > g.copy vect=roads@PERMANENT,myroads
GRASS 6.3.svn (spearfish60):~ > v.db.connect -p myroads
Vector map <myroads@user1> is connected by:
layer <1> table <myroads> in database </home/mlennert/GRASS/DATA/spearfish60/user1/dbf> through driver <dbf> with key <cat>
I also get the same result with a map fields@user1 connected to a postgresql table.
BTW, Martin: I like the highlighting of the queried feature in the edit mode. Could this also be activated in the display mode (which maybe should be called "query" mode ?) ?
Moritz
