[GRASS-dev] Re: [GRASS-user] modify feature's values interactively
On 31/03/08 13:54, christian Brandt wrote:
Date: Fri, 28 Mar 2008 17:38:44 +0100
To: chrisbrandt74@hotmail.com
CC: grass-user@lists.osgeo.org
Subject: Re: [GRASS-user] modify feature's values interactively
On 28/03/08 16:48, christian Brandt wrote:
Dear Moritz,
after implementation of wxPython GUI I started with a new grass
session with the command grass63 -wxpython. Then the following
message came up:
grass63 -wxpython Cleaning up temporary files..... Starting GRASS ...
Traceback (most recent call last): File
"/usr/local/grass-6.3.0RC5/etc/wxpython/gis_set.py", line 28, in from
gui_modules import utils File
"/usr/local/grass-6.3.0RC5/etc/wxpython/gui_modules/utils.py", line 1
There must be more to the traceback, and the interesting part is always at the end...
SyntaxError: invalid syntax
Error in GUI startup. If necessary, please
report this error to the GRASS developers.
Switching to text mode now.
Hit RETURN to continue...
Also: it would be helpful if you could give the following info when reporting issues with wxgrass:
- OS 10.2 64 bit
- python version 2.5
- wxpython version 2.5.2?
I'll leave this to the Mac OS X experts...
Moritz
