[GRASS-dev] Re: [GRASS-user] Problem with running Python script in GRASS
We really need a cookbook way to set up GRASS for Windows so that Python scripts run.
A couple students and I have struggled with this for the past 9 months. Although we’ve managed to get Python recognized by WinGRASS by running in a Windows terminal rather than Msys, we still can’t run scripts that call GRASS libraries or the parser.
Michael
Begin forwarded message:
Date: Tue, 4 May 2010 22:17:16 -0700 (PDT)
Subject: [GRASS-user] Problem with running Python script in GRASS
To: grass-user@lists.osgeo.org
Message-ID: <1273036636062-5007296.post@n2.nabble.com>
Content-Type: text/plain; charset=us-ascii
Hello fellow GRASS users!
I’m sure this is a very simple problem but I’m having a really difficult
time with it… After searching for the solution for several days I’m on the
end of my whits and am really needing this script to get working. This is
the problem:
I’ve written a Python script, doing my best to use the Python I know and
reverse engineer the python scripts I found in the Internet. As far as I can
tell, the script should be fine, although I naturally can’t execute it
independently. My goal is to run it as a command from inside GRASS so that
the user can input the parameters through the GUI. I think GRASS recognizes
that the script is there but isn’t able to generate the GUI.
Here’s the script:
MODULE: r.solar
AUTHOR(S): Daniel Lee
PURPOSE: Runs r.sun for a year using different inputs for each month
COPYRIGHT: (C) 2010 by Daniel Lee
This program is free software under the GNU General Public
License (>=v2). Read the file COPYING that comes with GRASS
for details.
#%Module
#% label: Solar modeling tool.
#% description: Conducts a solar analysis for a year using empirical inputs
for each month.
#% keywords: raster
#%End
#%Option
#% key: elevin
#% type: string
#% gisprompt: old,cell,raster
#% description: Name of input elevation map (unit = meters)
#% required : yes
#% guisection: Required inputs
#%End
#%Option
#% key: aspect
#% type: string
#% description: Name of input aspect map (decimal degrees)
#% required : yes
#%End
#%Option
#% key: slopein
#% type: string
#% description: Name of input slope map (decimal degrees)
#% required : yes
#%End
#%Option
#% key: linkein
#% type: string
#% description: Name of input Linke atmospheric turbidity coefficient map
#% required : no
#% guisection: Optional inputs
#%End
#%Option
#% key: albedo
#% type: string
#% description: Name of input albedo coefficient map
#% required : no
#%End
#%Option
#% key: mapset
#% type: string
#% description: Name of the mapset containing solar data
#% required : yes
#%End
#%Flag
#% key: z
#% description: Generate map of sunlight insolation time (h)
#% guisection: Output options
#%End
#%Flag
#% key: y
#% description: Generate map of reflected radiation (Wh/m2)
#%End
import sys
import os
import string
import grass.script as grass
def main():
elevin = options[‘elevin’]
aspect = options[‘aspect’]
slopein = options[‘slopein’]
linkein = options[‘linkein’]
albedo = options[‘albedo’]
mapset = “@” + options[‘mapset’]
reflected = flags[‘y’]
duration = flags[‘z’]
step = 0.16
for day in range(365):
day += 1
Define month
if day == 1:
month = “01” + mapset
elif day == 32:
month = “02” + mapset
elif day == 60:
month = “03” + mapset
elif day == 91:
month = “04” + mapset
elif day == 121:
month = “05” + mapset
elif day == 152:
month = “06” + mapset
elif day == 182:
month = “07” + mapset
elif day == 213:
month = “08” + mapset
elif day == 244:
month = “09” + mapset
elif day == 274:
month = “10” + mapset
elif day == 305:
month = “11” + mapset
elif day == 335:
month = “12” + mapset
Define coefficients!
coefbh = ‘coefbh’ + month
coefdh = ‘coefdh’ + month
if not grass.find_file(elevin)[‘file’] or not
grass.find_file(aspect)[‘file’] or not grass.find_file(slopein)[‘file’] or
not grass.find_file(coefbh)[‘file’] or not grass.find_file(coefdh)[‘file’]:
grass.fatal(_(“Raster map <%a> not found.”) % input
Define outputs!
beam_rad = ‘beam’ + str(day)
diff_rad = ‘diffuse’ + str(day)
glob_rad = ‘global’ + str(day)
if duration and reflected:
insol_time = ‘insol_time’ + str(day)
refl_rad = ‘reflected’ + str(day)
grass.run_command(‘r.sun’, flags = ‘s’, elevin = elevin, aspin =
aspin, slopein = slopein, linkein = linkein, albedo = albedo, coefbh =
coefbh, coefdh = coefdh, beam_rad = beam_rad, insol_time = insol_time,
diff_rad = diff_rad, refl_rad = refl_rad, glob_rad = glob_rad, day = day,
step = step)
elif duration and not reflected:
diff_rad = diff_rad, glob_rad = glob_rad, day = day, step = step)
elif reflected and not duration:
coefbh, coefdh = coefdh, beam_rad = beam_rad, diff_rad = diff_rad, refl_rad
= refl_rad, glob_rad = glob_rad, day = day, step = step)
else:
coefbh, coefdh = coefdh, beam_rad = beam_rad, diff_rad = diff_rad, glob_rad
if name == “main”:
options, flags = grass.parser()
main()
After loading that into the appropriate directory:
C:\GRASS-64\scripts
and restarting GRASS, I enter the command “r.solar” into the command line.
The result is the following message:
File “C:/GRASS-64/etc/wxpython/wxgui.py”, line 473, in
OnRunCmd
self.goutput.RunCmd(cmd, switchPage=False)
File “C:\GRASS-64\etc\wxpython\gui_modules\goutput.py”,
line 354, in RunCmd
menuform.GUI().ParseCommand(cmdlist, parentframe=self)
File “C:\GRASS-64\etc\wxpython\gui_modules\menuform.py”,
line 1825, in ParseCommand
xml.sax.parseString(getInterfaceDescription(cmd[0]).decode(e
nc).split(‘\n’,1)[1].replace(‘’, ‘<?xml version="1.0" encoding="utf-8"?>\n’, 1).encode(“utf-8”),
line 1764, in getInterfaceDescription
raise IOError, _(“Unable to fetch interface description for
command ‘%s’.”) % cmd
IOError
Unable to fetch interface description for command ‘r.solar’.
I’ve tried this on two different computers, both with Windows 7. My belief
as to what the problem could be:
  • I’ve put the file in the wrong directory
  • I’ve got to somehow compile it before I can run it
  • It’s got to be imported somehow into the GRASS interface first
  • My syntax is somehow all wrong
  • I’m missing some component needed to initiate the GUI
Can somebody help me? I really need this for my thesis and, as always,
there’s a lot of time pressure. I’d be immensely grateful to anyone who can
help me further. Thanks a lot!
Best regards,
Daniel Lee
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Problem-with-running-Python-script-in-GRASS-tp5007296p5007296.html
Hello,
Thanks for the answer. Yeah, that's really strange. Now I've installed Linux
on top of Windows and tried running it there. I seem to get a step further.
Rather than spitting out that strange error message I get the following:
child process exited abnormally
And another window pops up, titled "dialog0".
Nothing more to report other than that... But now that I'm in Linux it
should work better, right? Does anybody have a fix or an idea of what it
could be? Thanks so much!
The desperate
Daniel
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Problem-with-running-Python-script-in-GRASS-tp5007296p5011558.html
Do you get any more detail than that?
That error indicates that an external command failed. In that
situation, it's helpful to know *which* external command failed.
Also, it's worth checking whether the script works without the GUI,
e.g. typing "r.solar help" from the command line.
