[GRASS-dev] Re: [GRASS-user] Problems with v.outlier and v.lidar.edgedetection
Markus Neteler wrote:
some minutes ago I have submitted a fix from Roberto Antolin
to fix a v.outlier problem. It fixes a crash if qgis=name
isn't used (so, maybe use that and it works)?
C question re that fix: (vector/lidar/v.outlier/main.c)
    /* Structs' declarations */
    struct Map_info In, Out, Outlier, Qgis;
    struct Option *in_opt, *out_opt, *outlier_opt, *qgis_opt, *passoE_opt, *passoN_opt, \
  *lambda_f_opt, *Thres_O_opt;
is the end of line "\" harmful or treated like whitespace?
Hamish
It's interpreted as string literal concatenation. In my experience,
it's useful with strings:
Okay for gcc:
fprintf(stderr, "blah blah"
        "more blah blah");
More appropriate:
fprintf(stderr, "blah blah" \
        "more blah blah");
I'm sure Glynn has details, but that is my understanding. I don't know
if the same issues apply with variable declaration, but it isn't
necessary at least with gcc.
Brad Douglas <rez touchofmadness com> KB8UYR/6
Address: 37.493,-121.924 / WGS84 National Map Corps #TNMC-3785
Okay for gcc:
        "more blah blah");
More appropriate:
        "more blah blah");
The use of backslash-newline sequence is only useful in preprocessor
directives, which are terminated by any line break (LF on Unix, CRLF
on Windows, etc) which is not immediately preceded by a backslash.
In the above case, it's entirely unnecessary; a newline is treated no
differently to a space or tab in normal C code.
As for string concatenation: the preprocessor automatically
concatenates adjacent string literals, i.e. those which are separated
only by whitespace. E.g. the following are all equivalent:
  printf("hello world\n");
  printf("hello" " " "world" "\n");
  printf("hello "
    "world\n");
